water pump wiring
Old Jul 10, 2012 | 12:26 PM
3rdCoastPowerSports's Avatar
Default water pump wiring
im wiring up a remote water pump. I was going to wire it to a hot wire that was hot 100% of the time and then put in an on/off switch. I got to thinking that isnt a good idea if you forget to turn on the switch. Could i just wire it strait up to a wire that is only hot when the key is turned on? do i need a relay between the two? my thinking is if i wire it directly to a wire that is hot only when the key is on then there is no need for a switch or a relay. is this correct?
Old Jul 10, 2012 | 07:30 PM
S10xGN's Avatar
Use a relay, those "key on when hot" wires are 20 gauge or smaller...
Old Jul 11, 2012 | 10:45 AM
Thank you sir, i ended up using a 30amp relay worked great
