102mm Fast LSX. Yes or no?
Old Jul 21, 2012 | 04:34 PM
Jvmun's Avatar
Default 102mm Fast LSX. Yes or no?
So ive been wondering this for a while now. I wanting to go with one of these but I'm not sure which one.
Why do I see more people with the 92mm set up as opose to the 102 mm set up on their LS1.
Which one is right for me?
I have stage 2.5 5.3L heads
and tsp v3 tourquer231/234 643/598 111 cam
Just some pics
Attached Thumbnails 102mm Fast LSX. Yes or no?-pc040976.jpg   102mm Fast LSX. Yes or no?-679.jpg   102mm Fast LSX. Yes or no?-3822_4_.png
Old Jul 21, 2012 | 04:43 PM
sepsis's Avatar
102 will be perfect for you.
Most people with a 92 either got a good deal or are to stubborn to believe that a 102 is not too big for a stock 346.
I think you would benefit greatly from a 102, but you'll need fuel rails, injector extenders and LS6 steam pipes (coolant crossover) IIRC.
Old Jul 21, 2012 | 04:46 PM
ULTIMATEORANGESS's Avatar
Smile
if youre looking for more get one.
Old Jul 21, 2012 | 05:23 PM
TransamGCS's Avatar
a 92 will be just fine for your set up but i prefer to go bigger so i have a 102 with a 92 throttle body. i think you see alot of people with the 92 cause they have been out longer than the 102 and up until recently was discontinued but fast started making them again also you dont have to buy alot of extras like you do with a 102. as sepsis said youll need to buy different fuel rails, use ls1 style injectors and get coolant crossovers and you will need to grind the water pump down a little to get it to fit properly.
Old Jul 21, 2012 | 09:34 PM
john563's Avatar
hey man got the d=same heads as you but i have a90/90 and was kinda wondering how much id benefit steppin up to a fast 102
Old Jul 21, 2012 | 10:22 PM
garygnu's Avatar
the fast 102 is worth 4 more hp ,you can probably get for the same price as a new fast 92.you will need new fuel rails and injector adapters with the 102 intake..use a 92 mm TB.
Old Jul 21, 2012 | 11:01 PM
Mike Morris's Avatar
102 is worth more power. You just have to decide if its worth the money and hassle to install it.
Old Jul 21, 2012 | 11:17 PM
Jvmun's Avatar
Yeah theyre pretty sweet heads. I
I guess Im just going to have to go with the 102mm. At least there'll be some improvement from ls6 intake.
Anybody know if a tune is required for this? Don't really know much about that.
Old Jul 21, 2012 | 11:19 PM
Jvmun's Avatar
Do you have a cam? Where did you tune yours?
Old Jul 22, 2012 | 01:41 AM
derrickman05's Avatar
I've got a tv3 with stage 1 ls6 heads and a 102/102 set up and a 100mm maf and 104 lid so I'm set up to move some air. I kinda think I went on the big side but I'm going to transfer a lot of the parts to a 408 when that time comes
Old Jul 22, 2012 | 08:32 AM
therabidweasel's Avatar
With all the red under the hood I cant tell if you have an a4 from the pic, lol. If you do you gotta bend the whit out of your fill tube. I'm installing one now, easily worth it IMO. I can only parrot back what ive read, but the 102 is just a superior piece, look for Tony mamo's threads on them. Hes been porting both for years and knows what's up.
Old Jul 22, 2012 | 09:28 AM
Jvmun's Avatar
Not sure what you mean by A4, but as far the intake I am leaning towards the 102 more now.
Now to port and tune.
Old Jul 22, 2012 | 09:56 AM
Yes you will need a tune with the intake swap.
Old Jul 22, 2012 | 10:18 AM
john563's Avatar
yeah its a 232/238 6xx 6xx 111lsa got it tuned at precision autosport in xenia ohio
Old Jul 22, 2012 | 10:36 AM
Y2K_Camaro's Avatar
I ask this because I dont know. Why would you use a 92mm TB with a 102mm intake? Do they not make a 102mm TB?
Old Jul 22, 2012 | 12:05 PM
sepsis's Avatar
They do but they are typically more difficult to tune and when you install them, you usually have to grind a bit off of the water pump to make it fit.
A 92mm TB won't choke the car at all until you're making some serious HP. The gains you get from the FAST 102 is more from the runner design, not because it's necessarily a 102mm opening.
From what I've learned on here anyways.
Old Jul 22, 2012 | 01:01 PM
Jvmun's Avatar
Has anybody gotten a TSP mail order tune? If not any places near or in Alabama with good tuning rep?
Old Jul 22, 2012 | 01:59 PM
Y2K_Camaro's Avatar
Cool. Thanks for clearing that up for me.
Old Jul 22, 2012 | 05:12 PM
TransamGCS's Avatar
sepsis is correct. if your going to do a mail order tune i would go with FROST
Old Jul 22, 2012 | 10:31 PM
A4 as in automatic tranny BTW. The fill tube needs to be bent. I slapped a cheap socket in the end to keep from distorting the opening and bent it against some wood blocks with a length of pipe...no worries for a 6 speed.
