Problem with nick williams 102??
Old Jul 24, 2012 | 03:46 PM
kent91011's Avatar
Default Problem with nick williams 102??
I have a 408 in a silverado just added on 230 afr heads and a fast 102 with the nw 102 (DBW). when i go to start i turn the key over to let to fuel prime up and notice it goes in to reduced engine power. so i get my scan tool out and it says code p1518 so i remove my intake check all grounds put it all back togeather and its the same. So to see if it was my x link i install a stock 4 bolt tbss tb and it fires up with no code. Any of you guys running a nw 102 had this problem. Is it a tune issue or something that i might have over looked??
Old Jul 24, 2012 | 06:38 PM
kent91011's Avatar
Any body?
Old Jul 24, 2012 | 06:43 PM
TransamGCS's Avatar
i think its a tune issue, if you havent tune it since you switched everything then thats where i would start
Old Jul 24, 2012 | 07:33 PM
Big Bu Bu's Avatar
Check the wiring harness to the NW servo motor. Check the voltage on the battery as well.
Old Jul 24, 2012 | 07:35 PM
Big Bu Bu's Avatar
This to. The scalar area table is different for the big TB.
