Ls2 throttle body on Ls6 mani
Old Jul 26, 2012 | 01:48 AM
slammedc5's Avatar
Default Ls2 throttle body on Ls6 mani
Aloha gang,
Other than the wiring adaptor harness, what else would I need to do to get the ls2 tbody to bolt on to an ls6 Mani with the 4 bolt 90mm snout?
Old Jul 27, 2012 | 07:08 PM
Darkman's Avatar
The LS2 throttlebody does not have coolant lines (for preheating) so if your existing throttlebody does not you wiil need to simply bypass the throttlebody connecting the input/output coolant lines. And you may need to run the pcv hoses differently. For example, on my CTS-V, I had to add an air input on the intake upstream of the throttlebody since the LS2 throttlebody did not have one like the LS6 throttlebody I was replacing.
Old Jul 28, 2012 | 11:55 AM
bww3588's Avatar
Send a stupid amount of money to TPIS to have it converted to a 90mm 4 bolt snout. Then it should bolt up fine.
Otherwise, it won't work.
Old Jul 29, 2012 | 11:20 AM
slammedc5's Avatar
Actually it will work.
Im going to use a 3 bolt snout, 85mm tyhoon, and bolts my ls7 throttle body to it
http://item.mobileweb.ebay.com/viewi...id=42427650764
