4.3 to 6.0 swap problems
Old Aug 3, 2012 | 11:10 PM
SCSB Chevy SS's Avatar
Default 4.3 to 6.0 swap problems
I m doing a 4.3 w/manual trans to a 6.0 that originally had a A/T everythings connected but the engine wont stay on could it be the neutral safety switch??? Because im using the wire harness for a A/T??
Old Aug 4, 2012 | 08:52 PM
LS1MCSS's Avatar
Have you had vats turned off in the PCM?
Old Aug 4, 2012 | 11:13 PM
my1994z28's Avatar
Sounds like VATS...They did a 4.3 to 5.3 swap on Horsepower,and it had the same problem..it would start then stall..its was the VATS...good luck
Old Aug 6, 2012 | 08:13 PM
No I have not turned it off what is vats?
