FTP lids Cracking?
The material we use is not brittle but there are two parts that are glued together and sometimes the glue comes apart and needs to be reglued. Other than that, the material has proven to be very reliable.
Mine cracked even more around seams yesterday. The cracks were alredy there. They just split more. Around the maf. I have z06 maf also. I used electrical tape to wrap it so it doesnt pull air thru the cracks.
Had to remove for oil change
They help, foam alredy has a adhesive backing side.
But still eventually it wears thru.
I always kept the foam pads. Found a use for em.
I would actually pay more if they could use a better quality plastic.
The lids are vaccuum formed from two pieces which are glued together at the neck and base of the lid. Sometimes the glue does fail at the joints and requires regluing. When this happens during the warranty period, you can send the lid back and we can send you another one or you can simple re-glue it yourself. There is no way to avoid the joint issue except for going to an injection mold which has a huge initial mold cost.
SLP lids were originally vacuum formed but many years ago they moved to injection molded construction. That is a more durable and precise plastic contruction method but requires very high volume to pay for the mold. SLP also offered OEM blackwing lids which no doubt helped to offset the costs. SLP air lids are only offered for the stock size MAF (largest market segment). We sell and recommend the SLP air lids for those people that only have slightly modified vehicles that would not benefit from a larger lid/MAF.
Considering that 98 and 104mm lids only appeal to a smaller volume of the consumer base (higher HP builds), we were not able to do an injection mold for these lids.
We use an vaccuum formed ABS plastic which is normally very durable. Like all plastic however, it can fail under certain conditions (heat, pressure, exposure to chemicals etc). Anyone that has had a plastic fatigue problems (tabs or front of lid near latch mechanism) from normal use that originally purchase the lid from FTP or one of our authorized dealers can contact us for warranty repairs. You must have a receipt for proof of purchase. We handle each on a case by case basis and have helped out original purchase customers even well beyond the warranty period.
If you purchased your lid used, we cannot assist you. That is one of the advantages of purchasing new directly from us or from one of our authorized dealers.
As far as hood rubbing goes, there is no way to prevent this without significantly downsizing the lid which will affect the flow and performance. We recommend placing some soft adhesive velcro in the contact spots on the hood to prevent paint rub through.
There is a modification you can perform to slightly drop the lid on the base of the air filter assembly but this is at your own risk and voids any warranty on the lids. You can email us for details if you want to perform this modification.
Considering most of the high HP LS1 engine builds utilize the FTP line of airlids, we have only received a very small number of warranty issues. Again, we handle each concern on a case by case basis.
We encourage people that experience problems with our products to contact us directly. There is no way we can monitor and respond to all message forum posts.
Sincerely,
FTP
For anyone else that bought a lid new from us our one of our dealers and has plastic fatigue problems like this, give us a call. We handle warranty concerns on a case by case basis.
Guys, we have been selling these a LONG TIME and you only see a tiny number of complaints. The sky is not falling!
But as far as it rubbing on the hood, IMO that's the nature of the game with going to a larger lid. Doesn't bother me as much. Kind of like if a C5 guy bashed FAST for their 102 intake not clearing their cowl. But I'm really not a fan of the flimsy plastic and poor fitment.
It is what it is though. I'm not pissed, just a tad little disappointed is all.
Forgot I had this video.
