Need Help! Cant get motor running
I also checked the harness grounds again. There are 3 of them connected to the driver side head, and my vom shows a closed loop to the firewall, 0.3ohms.
So i feel like i'm still trying to find out why the injectors quit pulsing. Is it possible to back probe the wires at the ecm? Do the plastic covers pull off? Can you check the crank signal with a VOM? or is it too fast of a pulse?
I have had the vats checked twice. The tuner pulled it up on hp tuners and looked at it and it showed vats off. Is it possible for it to show vats off but for the vats still shut down the injectors? I wish someone had a similar set up near me then I could see if my computer could run their car. I know someone with a stock fbody but I don't think my computer would work with his set up. Mine is tuned for a big cam, 60 lb injectors and boost. Any chance my ECM would run his car?
https://ls1tech.com/forums/conversio...t-baffled.html
There are others who have experienced the same. I'm not saying that this is positively the trouble, but it sure looks that way.
You could try contacting John @ Speartech, or Steve @ Tuned By Frost.
If you decide not to go that route, try this.
Here is an inexpensive VATS bypass sig generator. Whether the ECM appears to be on or off is of no consequence. Just hook up the generator, and it will send the correct sig to the ECM to enable fuel pulsing. http://www.ebay.com/itm/GM-VATS-or-P...069889&vxp=mtr
