vacum sensor
Old Aug 10, 2012 | 08:17 PM
leon phelps's Avatar
Default vacum sensor
Hello,
Have this sensor that was mounted on my ls1 near the fuel rail flex line.
It is not hooked up and I needed to remove it to put an engine cover on.
It never had electric, so that part is easy.
As for the vacum line, I have it disconnected. The engine runs fine, I do feel slight vacum on it when engine running. Do I need to cap it off or can I leave it as is?
where line runs to
and roughly where it sat before it was removed.
thanks for any input.
Old Aug 10, 2012 | 08:49 PM
LS1MCSS's Avatar
cap it.
Old Aug 10, 2012 | 11:36 PM
therabidweasel's Avatar
Fyi that is the solenoid for the air system and that line goes directly to the intake which is why it needs to be capped.
Old Aug 11, 2012 | 06:15 AM
thanks. I will probably find some sort of plug to fit in the hose, will make it an easy plug.
