FAST 102 or FAST 92 346/LS6 engine
Old Aug 23, 2012 | 12:09 PM
Lockdown99ss's Avatar
Just don't blow your engine! Easy enough haha
Old Aug 23, 2012 | 12:25 PM
badazz81z28's Avatar
For Sure! I just wasnt sure if the power increase on my engine was worth it. That FAST 92 is fukin too expensive when I can get a 102 for over $100 less!
Old Aug 23, 2012 | 01:49 PM
99Bluz28's Avatar
IMO, if you're already worried about resale value then don't buy it, just start putting that money aside for you future LS3 engine, or a 9" rear!
Old Aug 23, 2012 | 07:21 PM
I need an intake tho....
Old Aug 23, 2012 | 10:31 PM
01ssreda4's Avatar
Originally Posted by badazz81z28
The cheapest FAST 92 I could find is $834 shipped. The cheapest FAST 102 I could find was for $720 shipped. Both Brand new.
I have researched the install and seems the Fst 102 TB is the issue, I plan to run a 92mm
Correct, the bigger TB causes some of the install issues. And you're one step ahead having the fuel rail already. But, consider this, you could sell the rail and put that towards the 92, thus making it cheaper. Food for thought.
Originally Posted by redtan
Pretty sure the 92 is not cheaper.
Pretty sure a manifold is the same to install regardless of the opening size in the front.
Pretty sure a radical H/C 346 will benefit from having a 102 over a 92.
But hey, if it works for you it works for you.
No, sorry. Try again.
Old Aug 23, 2012 | 11:48 PM
bww3588's Avatar
No...please. do not "try again"
Old Aug 24, 2012 | 01:21 AM
Blk98Vert's Avatar
Both will resell just fine. Since you have access to the LS2 rails it makes no sense to buy the 92, you will save a chunk of change and have a better intake
Old Aug 24, 2012 | 08:30 AM
thunderstruck507's Avatar
Grab a stock intake to hold you over?
If you already have the new rail and the 102 is cheaper, buy it. You definitely will not make any less power than the 92 and have the potential to make more.
Old Aug 25, 2012 | 10:30 PM
I bought a FAST 102...$725 shipped Brand New.
Old Aug 26, 2012 | 06:46 AM
DisasterpeaceWS6's Avatar
Originally Posted by bww3588
Oh, and BTW the 102 is more difficult to install.
Whats makes the 102 harder to install? Im actually installing one on tuesday. Give me couple tips if you dont mind.
Old Aug 26, 2012 | 08:21 AM
Undertow74's Avatar
i have pulled/installed my fast 102 a couple of times now, and if you find installing the intake a difficult job, you probably should not work on your car. a little more patience, yes. since the intake is taller you have less room to work with around the cowl. hardest part is putting some zip ties around the rear 2 bolts on both sides of the intake to hold them up in place when installing. all described in the instructions when you get the intake.
Old Aug 26, 2012 | 05:58 PM
  #32
Yea I was reading the install process on instructions and it doesn't seem that hard really..just take your time
Old Aug 26, 2012 | 06:34 PM
  #33
1nasty86's Avatar
Turd Gen Guy
Just anyones fyi.... You cannot use a nick williams 92mm throttlebody on the fast 102 intake and it seal properly... Use the fast 92mm tb or if u have a dbw use the ls2/3 throttlebody... And they make a product called the vmax ring for a 92mm throttlebody install on a fast 102.. It goes behind the throttlebody
Old Aug 26, 2012 | 07:38 PM
  #34
What is the issue with the NW? I thought FAST and NW looked identical.
