BBK SSI intake
Old Sep 1, 2012 | 02:34 AM
Z28Dave's Avatar
Default BBK SSI intake
just bought one from a fellow member here on the tech, did i make a mistake or am i good to go? have the stock LS1 intake and was looking for a upgrade when i swap my hpe megadeth cam, yes i know heat sink metal intake on metal heads metal pistons metal engine haha i got a good deal, also got a rollmaster double roller timing chain will this go well with the setup?
Old Sep 1, 2012 | 03:46 AM
MasterTomos's Avatar
It's been the general consensus on here that it's about equal to an LS6 intake as far as an upgrade in performance goes. Some speculate heat soak will be worse, and as a result, less power when hot-lapped/ran for a while, but I have yet to see solid proof of that on here.
Most owners seem to be happy with them though, and if you decide to go another route, you should be able to sell it very easily on here in the classifieds.
Take a gander at the results in the search bar, this has been talked about a lot in the past and there's a lot of info on it.
Old Sep 1, 2012 | 11:43 AM
Bramlok's Avatar
It's a good intake. Plus it looks better than the LS6. I think it will perform a bit better as well. It's not a FAST but still a good upgrade over the stock LS1. I don't buy into the heat soak issue that's been beat to death around here.
Old Sep 1, 2012 | 02:22 PM
Sales1@Texas-speed's Avatar
Since you've already made the purchase I see no reason for you not to run it. Obviously it wouldn't be my first choice but it should be decent upgrade over the stock ls1 intake.
Old Sep 2, 2012 | 02:31 PM
WS600461's Avatar
I have one and love it. It's not a fast but for the price it's a good deal
Old Sep 6, 2012 | 03:08 AM
Soul TKR's Avatar
It's the best intake to get right under a F.A.S.T.
And actually there has been a documented increase even over an LS6
Don't listen to all the heat soak crap... it shouldn't even be mentioned anymore in these threads.
Old Sep 6, 2012 | 06:20 AM
LS-ONE_DAY's Avatar
This +1
Old Sep 6, 2012 | 12:42 PM
MikeWS6's Avatar
I was going to buy one until I saw how much it weighed. Ended up w / ls6 and im happy. Its a good intake for the money though.
Old Sep 7, 2012 | 09:06 AM
2nd Gen Fl 'bird's Avatar
~11 lbs more than a LS6. Not much to worry about.
Old Sep 7, 2012 | 09:16 AM
LS1LOL's Avatar
I'll trade you my ls6 intake if you decide you don't like it.
Old Sep 8, 2012 | 05:47 PM
84olmpcboy's Avatar
I picked up a ported bbk on here for $300 the other month. Already had headers and a 85mm throttle body on. BBK really woke the car up over the stock ls1. Don't buy into the heat soak, might happen when your around town but at wot the air is going through so fast it wont get any hotter or colder than when it hit the air box. Do a search, someone dynoed it and bbk is 15-20hp over ls1 and 5-10 over ls6 IIRC.
Old Sep 8, 2012 | 11:18 PM
99Bluz28's Avatar
IMO, I'd get a 85mm TB for it to maximize you gains. If you're willing to open up the inlet a little then a Edelbrock 90mm TB should work fine.
http://www.ws6project.com/user_stor/...throttle-body/
http://www.coloradospeed.com/edelbro...s2-p-8739.html
Old Sep 9, 2012 | 02:32 AM
KrisXpc's Avatar
I ran this intake for 3 years and loved it. Only reason I honestly upgraded to a FAST 90/90 is because I had the money.
Old Sep 9, 2012 | 03:36 AM
poloaa009's Avatar
Old Sep 9, 2012 | 04:02 AM
Anthony Williams's Avatar
Love mine,no issues and price was right..
Old Sep 9, 2012 | 06:05 AM
My6speedZ's Avatar
Run it, you'll be happy you got it.
Old Sep 10, 2012 | 02:19 PM
Soul TKR's Avatar
Except for the additional 5-10rwhp that is...
Old Sep 10, 2012 | 02:54 PM
MikeWS6's Avatar
Ive seen ls6's dyno higher. Just depends on the day and the dyno.
Old Sep 10, 2012 | 05:17 PM
Bramlok's Avatar
All things considered equal, same day, same car, same dyno, same conditions, the BBK will make 5-10hp more power than an LS6.
Old Sep 10, 2012 | 07:39 PM
My6speedZ's Avatar
In a set-up that can utilize the additional air flow, at some point in the RPM range the BBK will begin to pull away from the LS6
