security/starter issue? '00 t/a
Go to start up the car, push clutch in and nothing if i take key out, the security will stay on. happened earlier today, took the battery out (figured it might help or at-least try) and nothing, let it sit for about 10 mins with key in ignition and finally fired up. Its just like when you turn they key w/o clutch in nothing all lights come on and no dimming so battery should be good. but last time it happened i let it sit for about 10 minutes and it fired right up. I'm so confused
Going to try a few things.
*swap the relays.
*possible new key (could be a bad resistor??)
*take starter out and test it at advanced.
*clean the battery connections real good.
Only things i have done within the month is,
-tick 2 rebuild m6
-change headlight gears
-interior led's
-ls6 clutch
-(i know some of this may not cause it but cant be to safe.
I have known about ls1tech for about two years finally made a account since i bought a ls1, any inputs will help, sorry if this may be the wrong thread. thanks guys.
Yesterday, I finally fixed the issue for the friend I sold the car to. For him, the security light would flash and the car wouldn't start. Turned out to be the VATS and I fixed it for him for $6.50 (I needed 5 different resistors because of his number!). Bypass your VATS and enjoy starting your car!
