Anyone replace their ignition cylinder?
Had mine done yesterday.
Disconnect the battery
remove the air bag (screws on the back)
remove the sterring wheel nut, use a puller and pull the wheel
remove the electronic piece under the wheel
remove the screw that holds the emerg flasher on
remove the clip that hold the metal plate down (the key guy used a type of puller that pushed down on the plate to make getting to the clip easier)
Here I saw that the wire was broke. He cut the wire and pulled it DOWN the steering column
reversed to reinstall
Hope it helps
the dealer replaced minethis seems like a common problem on fbodies.... i see these threads here and there once in a while
http://shbox.com/ignsw/ign_switch_repl.html
www.ls1tech.com/forums/showthread.php?t=106241
