manual-single plane guys ??
Old Dec 22, 2013 | 11:50 AM
LSOHOLIC's Avatar
Originally Posted by SNLPerformance
Here's a Trex cam(47*) in a Camaro with Fast 102 through 4.56 geared 9", 28" slicks and 54lb clutch assembly, fwiw this car we built made 500rw on another local dyno...
346" ??
Which Trex version ??
Looks good....
Old Dec 22, 2013 | 11:53 AM
LSOHOLIC's Avatar
Originally Posted by Martin@Tick
With your compression addition you've discussed that would be ideal.
The only problem IMO is your current cam does not have enough overlap to beat out a similar grind with tighter center lines.
239/246 .624/.595 107lsa 104icl.
If you really want to try to stretch the curve out and sacrifice some peak and under the curve put it on a 108lsa/104icl
looks very interesting........holy 29* of overlap batman.........LOL....loving that IVC !!
Old Dec 30, 2013 | 11:21 AM
LSOHOLIC's Avatar
I would really like to see some dyno graphs of 346" single plane setups.....please !!!
Old Dec 30, 2013 | 12:13 PM
SNLPerformance's Avatar
Originally Posted by LSOHOLIC
346" ??
Looks good....
Sorry I missed this...
Yes, 242/248 110+4
Not a single plane, but a 43* IVC compared to a 44.5* IVC in my car if you haven't seen it before -8* overlap vs -9.5*...no other changes, same dyno and tuner
https://ls1tech.com/forums/manual-tr...hims-help.html
Good luck in finding the comparison you're looking for.
Old Aug 31, 2014 | 09:29 PM
LSOHOLIC's Avatar
Thought i would bump this back up....
Any single plane 346" dyno graphs to share ??
Old Oct 18, 2015 | 10:21 PM
LSOHOLIC's Avatar
Bump ttt......
Single plane 346" N/A data
Thanks....
