main engine harness.
Old Oct 4, 2012 | 04:16 PM
oldmano2z's Avatar
Default main engine harness.
hers goes : have intermintent wiring issues @ the pcm with the 1153 code it's at the tuners and he's about to pull his hair out. the sometimes wiring problem. the hard to track down one. it's pretty well isolated to the wiring @the pcm area. i had wrecked it on the right side a year ago also checked aALL wires before assembly no issues. could my pcm be damaged? crash pushed that part of fender back some . could jarring that make something inside intermitant?? new harness anyone know where a new one would be at?(ha ha!) does anyone build a replacement? this **** sucks!! this means i might have to go thru the whole harness looking for shorts and opens? would you guys try a repop pcm with my tune installed FIRST to see if it was damaged during crash?? AT WITS END! the oldman.....
Old Oct 4, 2012 | 05:44 PM
gMAG's Avatar
Perhaps this info will help....
From another old man.
https://ls1tech.com/forums/pcm-diagn...153-codes.html
and..
http://search.yahoo.com/search;_ylt=...8&fr=yfp-t-701
Old Oct 5, 2012 | 10:25 PM
oldmano2z's Avatar
thanks, gMAG. lots of info there lots and lots of horror stories of hit and miss. i hopefully got mine fixxed by my tuner. insanely smart man and a great person to deal with.loose pins in the pcm harness possibly due to the collision i had was what was found in my case. thanks again .. the oldman....
