Fuel injector question
Old Oct 5, 2012 | 07:13 PM
Killemall760's Avatar
Default Fuel injector question
I just pulled my fuel rails from the intake and when the fuel injectors came off the little plastic o ring on many of the injectors cracked and broke.
Can i just replace the rings? or do i have to buy new injectors? or can i just remove them all.
Old Oct 6, 2012 | 06:41 AM
Old Geezer's Avatar
Lightbulb A hint
Try the correct forum.... Someone may have the parts you need, for a really right price.
And, no U don't have to replace the injectors....
Old Oct 6, 2012 | 06:04 PM
gMAG's Avatar
Fuel Injector Connection (sponsor) should be able to replace those.
Old Jan 5, 2013 | 10:38 AM
seweber's Avatar
i have this problem how didi you make out with it. what is that ring called
Old Jan 5, 2013 | 07:44 PM
99VetteFRC's Avatar
The plastic piece doesn't affect the operation of the injectors. I took the rings off my LS1 injectors to make them work on the truckintake.
Old Jan 5, 2013 | 07:56 PM
badazz81z28's Avatar
Don't they hold the o ring in place?
Old Jan 5, 2013 | 08:08 PM
99VetteFRC's Avatar
Only when removing the injectors, just keeps the o-rings from sliding off the injectors and staying in the intake apon removal. The intake has a step in the injector hole so the o-ring can't get sucked down into the intake under negative intake pressures.
