LQ4 Swap guys cmon in
Old Oct 7, 2012 | 11:12 AM
JeaneGrae's Avatar
Default LQ4 Swap guys cmon in
Fellas im thinking of going with a forged lq4 set up in my Trans Am. For those that have done the swap, please give any input. Regrets, pros, cons....
Old Oct 7, 2012 | 12:00 PM
Pharcyde50's Avatar
I'm running an Lq4 stock block and crank, Wiseco Pistons, K1 Rods, Custom cam, PRC 2.5 243 heads and ported Fast 102. Pretty good setup runs like a beast.
Did add some weight so I went to a light weight AGM battery up front and did some other weight reduction. Vid in the sig , running a ls6 intake in the vid just got the fast and new fuel system installed. Gonna hit it with a 150 shot and see if I can clip off some 10 sec runs.
Old Oct 7, 2012 | 02:26 PM
CHADsterss's Avatar
I regret not milling my heads!
Old Oct 8, 2012 | 08:58 AM
JeaneGrae's Avatar
Default Lq4
What times and dyno numbers are you guys making.
Old Oct 8, 2012 | 10:48 AM
CHADsterss's Avatar
No time or numbers yet... I'm hoping for 380-400
Old Oct 8, 2012 | 09:52 PM
JaYZeig's Avatar
love my lq4 swap in my 99 t/a
pretty straight forward swap, other than having to drill the block and tap it for the alternator bracket, thats pretty much it.
im on a stock shortblock, cam, and headstuds, and i made 640whp/670tq on 10 pounds boost, this engine can definitly take a beating!
Old Oct 11, 2012 | 03:59 PM
AINT SKEERED's Avatar
Mine made 452/422 with mild ported 241 casting heads and a f14 cam, fast 90 and victor race headers through a 12 bolt and 4.10 gears. Heavy steel drive shaft on 17" wheels.
Runs 11.32 in street trim on Nittos
All on stock lq4 pistons and 10.2/1 compression
