Possible vacuum leak?
Old Oct 17, 2012 | 12:29 PM
alexus6798's Avatar
Default Possible vacuum leak?
Hey guys, I just got my car back up and running from installing a fast 90/90 and 85mm MAF. I sent my pcm off to Frost to get it tuned and got it back and got everything buttoned up. Went outside to fire it up and cars runs good. I know it takes a while to relearn idle and stuff but my problem is when I turned on AC, it just blows out defrost and floor. My car has never done this. I'm thinking I have a vacuum leak, atleast I hope it is something simple like that. I am not a mechanic and don't really have any tools or every did anything like this. Is there a simple safe way to check for vacuum leaks that can be done with basic tools? When driving the car I can feel a noticeable better throttle response but you can kind of feel it fall on its face when getting of the gas if you know what I mean. Any ides or help is appreciated....
Old Oct 17, 2012 | 12:54 PM
Undertow74's Avatar
you say you swapped manifolds, i am willing to bet the small vacuum line that goes to the back of the manifold is either loose, or fell off. I would check that first. Your Blend door controls for your vents are controlled by Vacuum
