Thermostat Degree Selection
Old Oct 18, 2012 | 10:23 AM
Finally's Avatar
Default Thermostat Degree Selection
I think I have the wrong or a stuck open thermostat in my 2000 SS. I can't seem to get a reliable answer on what degree the thermostat should be rated for this engine. I hear 195 degrees and 186 and 180 on various threads.
Napa shows 186 degree for their THM 506186 Heavy Duty stat, and Advanced Auto has Stant 14948 thermostats rated at 186. It seems the 195 is for the V6.
Please help...I'm freezing my nads off waiting for this engine to warm up.
Old Oct 18, 2012 | 11:15 AM
Element's Avatar
186* should be the stock rating for an LS1.
Old Oct 18, 2012 | 05:49 PM
MMWS6's Avatar
2000 was 180* stock. Can't say if vehicles headed to the US were different, but in my catalog** I work for GM, the rating is 180*
Old Oct 18, 2012 | 06:00 PM
M1SERY's Avatar
Default thermostat
had a question i have a 160 in my car and its throwing p0128 code which thermostat threshold is this normal or is it sticking , have a new one just dont want to throw money away , maybe mine is sticking every once n a while , dont know . what say u???
Old Oct 18, 2012 | 06:54 PM
MMWS6's Avatar
That code is common after a 160* thermostat is installed from what I've read. It trips when the car runs at a low temp for too long. You should just have the code deleted in your tune or install a higher temp stat.
