stupid ignition problem
Old Oct 23, 2012 | 09:53 PM
sz28aro's Avatar
Default stupid ignition problem
im having a problem with my radio and window working after starting my car. if the key is in run radio and windows work. with car running both stop working. also the when turn the key backwards get nothing.
tried a new ignition switch same results. if any one has had this problem please chime in. thanks.
Old Oct 27, 2012 | 09:08 AM
streetknight2's Avatar
Sounds like the adjustment of the ignition switch is off. It's a pain to mess with, but I fixed one a couple weeks ago with a similar issue. Just loosen the bolts and move it a little and tighten up, have to keep messing with it till you find the sweet spot
