electrical/mechanical oil pressure shake?
Old Nov 13, 2012 | 10:31 AM
idlerelaxation's Avatar
Default electrical/mechanical oil pressure shake?
check out the amount of shake i have on oil pressure gauge, oil pump is an ls6 done with cam swap, does it seem to be electrical or mechanical? o ring leaking air(doesnt seem since constant under throttle)? sensor(id think throttle vibration would cause connectivity isssues, not idle)? cluster?
http://youtu.be/gb61iUNHa3M
Old Nov 13, 2012 | 12:27 PM
454ragtop's Avatar
Bet it's a worn sending unit. Thats probably where it spends most of its time, hence the wear. It seems to smooth out soon as you rev it a little, generating higher pressure, and hence a different spot in the sender. I'd either temporarily hook up a mechanical gauge, or just replace the sender.
HTH, Jim
