Car has extended cranking before start?
Thanks Craig
Put a fuel gauge on it, if it doesn't get at least 50psi as soon as you turn the key on and hold it then there is an issue with the pump or the return check valve in the pump assembly.
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
