Dyno tuned, bolt ons, numbers inside!
Old Nov 20, 2012 | 05:05 PM
WS6Dream's Avatar
Default Dyno tuned, bolt ons, numbers inside!
Finally got everything finished up. Mods listed.
2000 Trans Am WS6 A4
349.66 rwhp, 352.97 rwtq
All Mods on car:
TSP 1 7/8 Long Tubes
TSP ORY
Magnaflow #16723 Catback
3.73 Motive Gears with Moser Axles
SLP Lid
Descreened MAF (not that I really wanted to do this)
LS6 Intake Manifold
Prothane Motor Mounts
UMI Weld-In Subframe Connectors
Dual DMH Cutouts (tuned with cutouts CLOSED)
Now, what does SAE Smoothing 5 mean? That just means corrected to temp and pressure, correct?
Old Nov 20, 2012 | 06:58 PM
KrazyKamaro's Avatar
Yes and no. Yes it corrects for temp. and altitude so that your numbers should be somewhat comparable to others at different locations. But it also actually smooths out the curve or line of the graph. Well that's what the smoothing factor does. Other wise the graph would look really bumpy and choppy. You know how the end of your graph jumps up and down a bit, well your whole graph would look kinda like that with the end of it being even more pronounced.
Nice Numbers by the way!
Old Nov 20, 2012 | 08:17 PM
Mazzenger's Avatar
Was the pull w/the cut-out closed or open?
You might check into why it is breaking up before 6,000 rpm?
Numbers are good for an A4.
Old Nov 20, 2012 | 08:39 PM
WS6Dream's Avatar
Cutout was closed for all pulls and tuning. And breaking up before 6,000 rpm, I have no idea about tuning or hp/torque curves - as far as what they should look like. You are referring to how the horsepower drops down, then up, then down, then up, then all the way down, right?
Old Nov 20, 2012 | 10:11 PM
StormTrooperZ06's Avatar
Good numbers for an A4.
Old Nov 20, 2012 | 10:14 PM
This is what a Dynograph looks like without smoothing. As you can see there are lots of little fluctuations between data points, especially on the Torque curve. Smoothing basically averages out the differences between these data points and uses a mathematical formula to best fit a line to them.
Old Nov 20, 2012 | 10:38 PM
WS6Dream's Avatar
Oh gotcha, thanks KrazyKamaro
Old Nov 20, 2012 | 11:59 PM
clean98z-28's Avatar
breaking up possibly valve float. mine was at 5500 when it was dyno tuned due to car sitting for years wore out the springs that were compressed when it sat.
 Michael S. Palmer
Old Nov 21, 2012 | 12:07 AM
}BlueFire{'s Avatar
How much hp/torque did you gain from the tun just curious?
Old Nov 21, 2012 | 12:39 AM
1FineSS's Avatar
Good numbers. Looking to be in this range with my A4 SS once I get all my bolt ons.
Old Nov 21, 2012 | 04:35 AM
WS6Dream's Avatar
I honestly can't answer that, never got numbers completely stock, and then also didn't get a baseline rwhp/rwtq run because the guy who did the tuning started before doing a baseline pull. But I can tell you that bone stock my car felt like it was lacking for sure, then even after all mods it still felt like it was lacking, but its a whole new animal now after the tune and I love it.
Old Nov 21, 2012 | 08:30 PM
joecar's Avatar
What is the rev limiter set to (in the engine calibration)...
Old Nov 21, 2012 | 08:35 PM
Blackpanther99's Avatar
Good numbers
Old Nov 21, 2012 | 08:37 PM
babbage1109's Avatar
I make close to the same with 1 3/4 headers full exhaust pnp tb lid and a street tune.
Old Nov 22, 2012 | 01:43 AM
ULTIMATEORANGESS's Avatar
stock stall still?
Old Nov 22, 2012 | 06:42 AM
SH1ZN1T's Avatar
I have similar mods plus a Shaner S2 P&P TB, GMMG and 3.42 gears. 361/365 (see sig)
Old Nov 22, 2012 | 09:36 AM
Blownbayou's Avatar
numbers right there with mine... nice
Looks like the ls6 intake is good for 13-14hp for sure
Old Nov 22, 2012 | 10:41 AM
WS6Dream's Avatar
Nice! Ya I have the shaner s2 throttle body as well I forgot to add I suppose.
Also someone asked about the stall, and it is still stock.
Old Nov 22, 2012 | 10:42 AM
WS6Dream's Avatar
Not sure what the rev limiter is set to
Old Nov 22, 2012 | 11:51 AM
SH1ZN1T's Avatar
I would suggest running it to 6k in 1st and 6200 2nd & 3rd.
