fast 102 sensor placement?? pic inside
Old Dec 13, 2012 | 05:47 PM
1bd63nova's Avatar
Default fast 102 sensor placement?? pic inside
i have a truck harness out of a 03 denali so the motor is a lq4 i putting a fast 102 intake on it and im trying to figure out if where to place the sensors in the intake any help would be great
Attached Thumbnails fast 102 sensor placement??  pic inside-photo-1.jpg   fast 102 sensor placement??  pic inside-photo-2.jpg   fast 102 sensor placement??  pic inside-photo-3.jpg   fast 102 sensor placement??  pic inside-photo-4.jpg
Old Dec 13, 2012 | 08:28 PM
badazz81z28's Avatar
That FAST 102 is designed for a car. The MAP sensor goes where the harness will allow. In your case looks like it will go best in the back.
As for the other sensor, what is that? AIT sensor? Other than the MAP, that 102 is not designed for any other sensor. I would think, that's why they make a truck FAST 102. You may have to re-wire it to put in in the air intake or in an integrated MAF
Old Dec 13, 2012 | 09:20 PM
82cetuner's Avatar
i think the truck TB have the sensors built inside the TB the the TPS and stuff, but yes only the MAP sensor goes on the intake and it can go on the front or the back, you may have to unwrap the wires from the harness and make them seperate if it isnt long enouph
Old Dec 13, 2012 | 09:56 PM
I also see you have TFS heads...I would opt for a 92 or 102mm TB over that adapter.
Old Dec 14, 2012 | 01:32 AM
1bd63nova's Avatar
ok yeah i know the one sensor is the part i posted in the box then theres like a air meter one that was tapped into the intake, im also gonna use this with a procharger so does the place matter? thought they need to be near the front..
Old Dec 14, 2012 | 12:44 PM
studderin's Avatar
is this going in a nova? The LSXRT has more performance
run a 102mm TB on that intake
Old Dec 15, 2012 | 11:12 PM
1bd63nova's Avatar
yes its gong in my nova its a 63.. i could find a truck one so i get this.. so sensors should be placed like on the stock intake? also who makes a 102 throttle body to work with a truck harness and is fly by wire?
