fbody power steering pulley
Old Dec 15, 2012 | 02:37 PM
90m3's Avatar
Default fbody power steering pulley
My motor came without a power steering pulley so I need one.
Can i use a pulley from a GTO?
I know they share front end accessories and the used pulleys are much easier to find than from a camaro or firebird. I'm trying not to spend $48 on a new pulley as I'd like to go with a turnone pump/pulley at some point -- just not yet.
Thanks
Old Dec 15, 2012 | 04:44 PM
2000PewterT/A's Avatar
I am not sure about this but I think the pumps are the same so the pulley should be. Hopefully someone that knows for sure can chime in when to get the right answer.
Old Dec 15, 2012 | 11:36 PM
jvert's Avatar
Yes you can use the GTO pulley but I do believe you have to get a bigger belt. I can't seem to find the link on the site that has the write up.
Old Dec 16, 2012 | 07:19 PM
bayer-z28's Avatar
Try these guys if you want aftermarket.
http://www.turnone-steering.com/street-accessories/
Old Dec 16, 2012 | 08:08 PM
trans_am7935's Avatar
i have this one and love it, i broke my stock POS one when removing it to change out the pump. you can also remove the power steering pump while the pulley is still on with this one.
Old Dec 22, 2012 | 01:04 PM
happysem's Avatar
Get the metal truck pulley from like a '04ish 5.3 Silverado.
Its a good quality, 99% the same size as stock, and only $16.
Old Dec 22, 2012 | 11:51 PM
01ssreda4's Avatar
That grey makes me want to throw up
Polished is where its at
