coolant crossover pipe leak help!
Not sure what else i can try, its a minor leak but enough to cause a problem.
Does anyone know if there are any crossover adapters i can fit with a barb fitting or am i stuck with it?
Get an LS3 style cross over and fix your issue the right way.
When you cut it, you removed the flares that do the sealing. Unless you actually reflared the ends?
post a picture.
Luigiandme- the center section of the steel crossover pipe i had to cut out and fit a hose to go under the 102 manifold, the factory pipe prevented the manifold from sitting flush at the front, there is a how to on here for this that i went by originally but it used the factory ends. Easier to explain with pictures.
