V-Band Question
Old Dec 28, 2012 | 10:55 AM
Ls_Notch's Avatar
Default V-Band Question
Ive got a ls swapped street/strip fox body and the class im going to run in requires mufflers so i plan on using some bullets. I was wondering if anyone has put v bands on the back side of the bullets and get a set of turbo mufflers with a vband them to put on for street use? It would be easy to take on and off I just wonder if the bands would hold the mufflers from spinning of would they need a hanger too?
Old Dec 29, 2012 | 12:04 AM
soundengineer's Avatar
when I had my camaro...I actually made a custom muffler setup that I had v-bands on....
I had a 4" Magnaflow muffler for when I wanted it quiet, and a Bullet for when I went to the track...
easy to change out on the ground or on a lift.
and sorry, I dont have any pictures of the v-band setup, but I went up over the axle with a 4" pipe, into a vband just before the curve, and I swapped out the entire muffler and turn to a dump
Old Dec 30, 2012 | 08:14 PM
Ls_Notch's Avatar
so would a vband clamp down tight enough so i wouldnt have to put a hanger on so I could take them off on and off easy?
Old Dec 30, 2012 | 10:35 PM
no... you still need some hangars in appropriate places.
and who says hangars make it hard to put on and off....
Just be smart about placement and its no issue.
