Oil Pressure..quick ?
Old Jan 14, 2013 | 06:05 PM
SSFBODY's Avatar
Default Oil Pressure..quick ?
so i recently replaced my bad cam sensor and like many, broke my oil pressure sending unit in the process..replaced the sending unit but could not tighten it fully, instead i used teflon and tightened it up abit... the car is running fine, except for my oil pressure guage is acting alittle abnormal.....it never goes over 60 and sometimes goes a little under 40 about 35....dont know if its just the sending unit thats causing the low reading or if im actually losing oil pressure....thnks for any insight
Old Jan 14, 2013 | 07:03 PM
trans_am7935's Avatar
sounds about right for a stock oil pump. pressure looks good, don't know what the problem is.
GMtechmatt's Avatar
do you have acess to a gen 3 oil pressure tester? it goes where the oil filter would be and with a gauge attached give you you mechanical oil pressure reading. but seeing you just replaced check the connectors and resistance
Old Jan 14, 2013 | 07:09 PM
SSFBODY's Avatar
well before my car was down for replacement of a bad cam sensor and fuel pump, my oil pressure would never go under 40 and at wot it would reach 60psi....thats wats been gettin me a little worried
Old Jan 14, 2013 | 07:10 PM
SSFBODY's Avatar
dont have one that i own but i can probably get one n try that out, thanks man
