is ls6 intake worth the upgrade ?
He meant in terms of trap speeds. With all things equal you should pick up MPH from swaping over to an LS6 intake.
Sex-LS6, Hand-ls1intake
Got mine for $250
with brand new seals. I knew the guy so.
lolOut of respect for the OP.... Lets try to get back on point and not have a debate in his thread.
damn good price..... Prob be upgrading this summer to LS6.
Dyno numbers vary.
What if OP was lead to believe his car would make what you make and gets on the dyno and makes less? Dyno numbers shouldn't be taken so serious.
The LS6 intake is better than an LS1 intake. Period. We all know this but it all depends on the price.
OP just look for one in your price range.
Dyno numbers vary.
Says the man married 19 years in April
There would be one on my ride right now IF I could find a decent, unmolested, used one which was not spray backfire-cracked by you kids with your damned laughing gas.
New, they seem to be the ONLY obsolete part for early 2000s LSxes which goes UP in price as time goes on, to the point where it is starting to pay to get a FAST 92mm.
As for the LS6 intake swap. I gained 24hp from the swap. My heads had alot of carbon buildup as well as the TB. I cleaned all that out as well when I did the swap. I am pretty sure that was robbing me a couple ponies.. With the LS1 intake my car ran a 13.2@106. When the track opens back up I will see what the car runs now with the LS6 intake and a little tune from my maft translator.
For free it was worth it but if my Typhoon makes 10-15 more HP then my LS6 did on my T/A I would say the best bang for the buck is the Typhoon as I got mine for 300.00 brand new..
Overall it's a great investment for a complete exhaust setup. You can spend 500+ with some what of a pita of labor installing headers for 10-15 more hp than than a ls6 swap.
This thread alone contradicts whatever your saying https://ls1tech.com/forums/generatio...-my-vette.html 24hp gain. And theirs just too many other threads like this.
As of right now without any dyno yet the Typhoon looks better then the LS6, gets just as hot as the LS6 when its running, and is easier to work around since its not as wide and strangly as tall on the sides as the LS6. I cant wait to get it on the dyno. If it makes 10-15 more hp then my car did with the LS6 I will be temped to get one for the Vette and get rid of the LS6 all together.
