compression/eE85 help !!!!!!!!
Old Jan 30, 2013 | 10:27 PM
95brobra's Avatar
Default compression/eE85 help !!!!!!!!
So here is the deal guys , i just picked up a set of 243 heads and i want to run 11:1 compression to gain some low end torque , i will be running Trickflow cam so i can pass smog in CA, Intake Duration at 050 inch Lift -- 216°
Exhaust Duration at 050 inch Lift -- 220°
Advertised Intake Duration -- 283°
Advertised Exhaust Duration -- 286° 560/560 max lift 114 lsa.
1) Should i have the heads milled .0065 and run a cometic .040 gasket to get 11:1 ?
2)Will this Combo be good to run E85 /91 octane ?
3) estimated rwhp ?
any advise will help guys i have ls6 intake , pacesetter shorties, bassani ory already
Old Jan 31, 2013 | 08:25 AM
Grr's Avatar
Grr
you can pretty much mill as much as you want with that cam. I would go to 11.5 myself
Old Jan 31, 2013 | 09:47 AM
95brobra's Avatar
thank you ,so do you think i should run a bigger cam like a tr224 to take advantage of the compression or will the trickflow be fine ? i wanna run 91 oct aswell
Old Jan 31, 2013 | 11:24 AM
Grr's Avatar
Grr
not too many cams will pas CA emmissions, so thats about all I would worry about if I were you
Old Jan 31, 2013 | 01:55 PM
5w20's Avatar
91 octane and E85 shouldn't even be in the same sentence.
Choose one.
Old Jan 31, 2013 | 05:13 PM
95brobra's Avatar
i hear you 5w20 ,Grr i think im just going to run the tfs cam and 11:1 and hope for the best on 91 oct i hope ill make good rwhp and a mean street car !!!!! any estimates ???
Thanks For the advice/help
Old Feb 3, 2013 | 04:23 AM
Streaty383's Avatar
I would go way higher on e85, I'm running 11.5 on pulp ( 98 octane though here in Australia ) I'm planning on jumping to e85 in the future and going to 13:1
