Will my LS2 MAF run with my 600hp setup?
Its currently running a speed density tune, but I plan on going MAF tune here in the next month, before track season opens.
I bought an LS2 MAF to run with my setup, but I have been reading that they only read correctly for up to 500HP. I have also read in other forums that they will read up to 700 correctly as long as its boost and not N/A. I dont know how that effects it, or if it really does. I also read on here that a stock LS7 MAF will read up to 800 and be fine. Will my LS2 MAF read correctly or do I need to change?
I found a guy locally that is selling a Lingnenfelter Performance mass air flow sensor. 100mm, and he wants $170 for it. Would that be a better choice than a stock LS7 MAF?
Thank you for your input in advance!
But, I don't see your Ls2 maf holding you back if you use it. There are people using stock ls1 maf's in applications such as yours.
Last edited by RickyB0bby; Feb 5, 2013 at 04:08 AM. Reason: I suck at typing. lol.
