knock sensor ?
Old Feb 11, 2013 | 11:34 PM
01transampower's Avatar
Question knock sensor ?
Will the knock sensor going off cause the gas mileage to take a dive? I know what's setting mine off but just haven't had the time to fix it. The mileage I get out of a tank now has dropped and was wondering if that could cause it.
Old Feb 12, 2013 | 02:53 PM
grim_ls1's Avatar
When spark knock is detected the Ecu backs off on timing until it goes away thus creating less power. It could affect mpg but I wouldn't think too much. What is causing the knock exactly, just curious
Old Feb 12, 2013 | 04:17 PM
Since i live in Colorado i have the sniffer test for emissions. Well my exhaust was true duals Two super cheap high flows 2 dynomax bullets and out the back. In oreder for me to get the car to pass had to put good cats. in the car. So I found a set on craiglslst out f an 06' gto. I cutthe old high flows out and put the gto oesin. The issue is they are big so I have low ground clearence and it is also vibrating across the underside of the floor and banging the floor so it's setting off the Knock sensor.
I plan on cuttng the cats. out but just no time and I was also thining about buying the tsp true duals or having a bunch of my exhaust reworked.
