installed motor no power to starter
Old Feb 22, 2013 | 07:53 PM
phenox's Avatar
Default installed motor no power to starter
so i finally got my t56 and ls1 in my car and got everything wired up i used a test light and am getting the 12 volts to the starter from the battery (new battery btw) but im not getting power to the small post, ive checked the clutch switch and it appears to working fine all fuses and relays have been tested and work fine, started tested out fine at autozone im stumped i have vats deleted on my pcm its a 98 trans am btw any help is greatly appreciated
Old Feb 23, 2013 | 08:23 PM
S10xGN's Avatar
The only way to tell is trace the wire all the from the starter terminal to it's power source. Do this using a continuity tester with the battery disconnected...
