engine Identification 6.0 lq4
Old Feb 23, 2013 | 10:42 PM
pwirth's Avatar
Default engine Identification 6.0 lq4
engine identification question
The book I have been reading states the 2007 Silverado has a GenIV engine. It also states that the gen IV has a Knock sensor on the side of the block and a 58x crankshaft sensor which is gray in color. the engine I have A 6.0 has 2 sensors in the lifter valley and a black sensor behind the starter that I believe is the crankshaft sensor, Is the book wrong? also I have a sensor in the stock oil pan that is not installable in my Holley pan i bought.
Attached Thumbnails engine Identification 6.0 lq4-engine-004.jpg   engine Identification 6.0 lq4-engine-001.jpg
Old Feb 25, 2013 | 05:11 PM
2000PewterT/A's Avatar
There should be a casting number on the on the rear of the block under the driver side cylinder head if memory serves me correct. Just take that number and cross reference it with the casting numbers with the ones online and it should give you a answer on what year block it is.
Old Feb 26, 2013 | 02:16 PM
omc8's Avatar
You have a LQ4 your 2007 Silverado is the old style called Classic . The Gen IV was put in the 2007 new body style NNBS the Gen IV 6.0 will be a L76 or LY6. Classic= Gen III NNBS= Gen IV
Old Mar 2, 2013 | 09:18 AM
pwirth's Avatar
Thanks guys
