Bought some gauges, question on wiring
Old Mar 4, 2013 | 09:22 PM
DeLaRosa25's Avatar
Default Bought some gauges, question on wiring
Got some electric glowshift gauges
Fuel pressure
http://www.glowshiftdirect.com/Tinte...ure-Gauge.aspx
Trans Temp
http://www.glowshiftdirect.com/tinte...ure-gauge.aspx
From my understanding (I think I read it right). I need this fitting and only this fitting?
http://www.metcomotorsports.com/prod...p?prod=MFF0001
To mount the sensor in the driver side fuel rail, and just run the wires accordingly? Or will I need more fittings under the hood to make it work.
And for the trans gauge. Just get a bung welded into the pan and wire up? Any certain position it should be facing?
Old Mar 4, 2013 | 10:36 PM
Chuck6993's Avatar
Your links don't work.
On my 4L60e there was a plug on the drivers side of the trans above where the gear select module is.
I pulled the plug and put in the sensor. They were the same thread. My sensor came with an AEM gauge.
Edit: "Temp sending units- The best place for these is in the pan since that will give the best average temperature which is what’s important, using the pressure port is ok however you will show temps 10 to 20 degrees higher average than you would in the pan. I do not suggest placing temp senders in either the inlet or outlet from the cooler as they will increase cooler restriction and increase the odds of a leak."
https://ls1tech.com/forums/8963689-post3.html
Attached Thumbnails Bought some gauges, question on wiring-2012-07-01-11.22.56.jpg
Old Mar 4, 2013 | 10:57 PM
DeLaRosa25's Avatar
fixed
