Cooling Temp Sensor Wiring Problem
Old Apr 20, 2004 | 08:53 AM
MECKER01's Avatar
Default Cooling Temp Sensor Wiring Problem
Just installed new rebuild. Everything is hooked up running good. Except my cooling temp sensor is not pluged in. Wiring plug has disappeared. So my question would any one have a pic. of the driver side of the motor around the cooling temp sensor. Or where does the wire lead from the main wiring harness. Cant find it.
Old Apr 20, 2004 | 10:03 AM
WILWAXU's Avatar
It comes off the injector harness.. part going down to the altenator.
Cool thing about LS1's.. all the plugs are different
Old Apr 20, 2004 | 12:06 PM
MECKER01's Avatar
Would you happen to have pic. can't find it not sure what happened.
Old Apr 20, 2004 | 03:51 PM
felton316's Avatar
Here is a pic of mine on my 98......
Sorry for the crappiness of the pic, but all I had was my cell phone to take the photo.
Old Apr 20, 2004 | 05:13 PM
MECKER01's Avatar
Thanks so it does lead from the harness that goes to the alternator. Is it a two or 3 prong connector.
Old Apr 20, 2004 | 08:25 PM
felton316's Avatar
The 97-98 should be a 3 prong, and the 99+ will be two prong (dummy gauge). Yes, its the harness that runs from the alternator up to the top of the engine.
Old Apr 21, 2004 | 08:39 AM
MECKER01's Avatar
Here's my problem I have a 98 with three prongs and a cooling sensor with 2 prongs from the auto parts store ???
Old Apr 21, 2004 | 11:26 AM
slick98ta's Avatar
Yeah the auto parts stores around here to give you the 2 prong sensor even if you say 98'.
I guess they all think 98- 2002 are all the same.
Take that one back and goto the dealer and get the 3 prong for a 98'.You shouldn't have a problem.Atleast no problems here going to a local dealer.
 Michael S. Palmer
