How do you do away with the egr ?
Old Mar 10, 2013 | 08:12 PM
JSlayman22's Avatar
Default How do you do away with the egr ?
I have a 2002 z28 with a LS1 i just built im putting pace setter headers on it and they dont have the holes in the top. How do I do a delete of the lines without causing any issues?
Old Mar 10, 2013 | 08:19 PM
justin hover's Avatar
Just remove them...then cut/tape off or hide the wires. You'll have to have the pcm codes tuned out. You have an ls6 intake correct?
Old Mar 10, 2013 | 09:20 PM
Decadence75's Avatar
You will also need either an EGR block off plate from one of the sponsors or a 1-3/8 rubber expansion plug for the hole that removing the EGR will leave in the intake.
Old Mar 10, 2013 | 10:28 PM
Zlow28's Avatar
you dont need to pass emissions right? If not, get rid of the AIR too
Old Mar 10, 2013 | 11:25 PM
ChewMT's Avatar
Pretty sure this guy is referring to the AIR and not the egr already. Seeing as though they didn't have egr in 2002
Old Mar 11, 2013 | 01:32 AM
King Nothing's Avatar
dammit beat me to it lol the last production year with EGR and AIR was 2000, 01-02 had the LS6 and they didn't run EGR (it's pointless anyway) only AIR lines. ls1speed sells the block off plates and i think TSP does too
Old Mar 11, 2013 | 03:08 PM
JSlayman22's Avatar
Ok thanks and yes its a LS6 intake.
