heads ???
Old Mar 14, 2013 | 06:55 AM
Mike Cordero's Avatar
Default heads ???
Do there is a difference between the 799 casting head in a 5.3L engine and a 243 casting in a LS2 engine, related to the combustion chamber size and bore size? It's the same to use a 799 from a 5.3 in a 6.0L engine?
Old Mar 14, 2013 | 08:26 AM
LS-ONE_DAY's Avatar
IIRC they are the identical. The only difference being that the 799 are is a sand casting and the 243 is die-cast so the 799 may be a little rougher.
