LS1 build PROBLEMS
I took off the valve covers and noticed one rocker jumped off the push rod, I know thats very uncommon and this isnt my first cam swap i Adjusted the rockers the same on others and they were fine. Anyway so i put it back together unhooked all the rockers none of them where adjusted correctly now a couple way to tight some too loose.. readjusted everythying check and double checked put it all back together started it and it sounds like a sewing machine. pulled the covers back off started playing with the rockers to try to see what was moving to cause this. My finger was able to collapse the lifters Im about 90% sure the lifters are collapsed. My question is wth caused all of this any ideas???
