Cruise Control Failure
Old Apr 7, 2013 | 08:37 PM
s7ven's Avatar
Default Cruise Control Failure
Well after thinking I didn't do any damage when my clutch pedal went out discussed in this thread:
https://ls1tech.com/forums/manual-tr...ut-clutch.html
Ever since I had to shift without the clutch, my cruise control no longer works. I don't understand how cruise control interacts with the transmission but I assume I fucked something up. Does anybody have any suggestions on where to start troubleshooting this issue?
Old Apr 7, 2013 | 09:28 PM
99Bluz28's Avatar
The switch up above the clutch pedal probably either broke or just got popped out of position.
Old Apr 7, 2013 | 10:10 PM
s7ven's Avatar
Thanks for the reply, I'll check that tommorrow.
Old Apr 8, 2013 | 01:18 PM
99monguse's Avatar
Clutch switch probably needs adjusting
Old Jan 2, 2014 | 10:18 PM
s7ven's Avatar
Thanks, my response is a little delayed but I wanted to report that the issue was with the upper clutch switch. The c-clip broke off that held the pedal to the cylinder and I think when I had it fixed the upper switch mount was displaced and therefore the switch was not being fully depressed.
Reinstalling the plastic switch mount resolved the cruise control problem.
