LS6 Slp intake.
Old Apr 19, 2013 | 02:54 PM
AviatorRL's Avatar
Default LS6 Slp intake.
I recently installed the LS6 SLP intake in my 2000 Trans am and I noticed a difference in fuel consumption. Is this Normal or is it just in my head? I checked for leaks on injectors but they all look good.
Only thing i have on is a lid.
Old Apr 19, 2013 | 03:07 PM
03Sssnake's Avatar
You are probably using your right foot more !!! The PCM could take several driving cycles before it re-learns/calibrates for that intake.
Old Apr 19, 2013 | 03:16 PM
AviatorRL's Avatar
LOL i think yes. Its been alot more fun to drive it. Car feels alot lighter in all gears too! N cool. 03Sssnake thanks for the reply.
Old Apr 19, 2013 | 04:24 PM
03Sssnake's Avatar
You are welcome! These intakes seal up pretty damn good, should not have any leaks as long as you made the vacuum connections at the back and to the pcv fittings. Your idle would probably hang if you had one and if it were a big leak, you would definitely know and possibly throw a check engine light.
Old Apr 27, 2013 | 12:09 AM
Zlow28's Avatar
Did you calculate your gas mileage before and after the intake swap? I usually check mpg before and after mods to see if there are any real changes.
