Budget 6.0 build
Any other suggestions for rods? I just want options to research.
In the end you can have a very stealthy 6.0 that will surprse a few people and still sound and look very tame
But then again I'm looking into an afr cam like mamos
224/228.
Tomorrow is pay day so some of my check is going towards my ignition cylinder getting replaced. Next Friday I'm ordering my racetronix pump with complete new factory assembly (ie float, bucket etc) I want to be sure my pump is good. I'm dropping the tank to clean it out.
What's the point of getting a block tanked? Is that just badass cleaner? I don't have a truck so it's kinda hard to take the block in my camaro to the shop so I was thinking about getting a mic and checkin the roundness of the cylinders and go from there.
Nobody has any suggestions pistons wise with the 2.02 valves. I haven't found anything on it yet but still looking.
As far as the hot tanking goes, yes its just an awesome cleaner. I have always had good luck with spraying it down with a good degreaser, scrubbing it and pressure cleaning it then blowing it dry with air and applying some grease to all the bearing and cylinder surfaces to prevent rust.
As long as you get a good bore gauge I dont see any issues with measuring your roundness and checking tolerances just be sure to measure it more than once to make sure you know exactly whats up.
my 6.0 doesn't have main caps. I guess I never noticed it. I don't want to go through the effort to machine used caps to fit. Iv been quoted 3-500 just for the align hone for them. **** that. I decided to sell the block let someone else deal with it and bore one of my 5.3 blocks to 5.7 specs. I hope I'm not giving up much power by not going with the 6.0. Ill update when I get my 5.3/5.7 back from the shop.
