98mm ftp lid
Old May 9, 2013 | 07:59 AM
spiderbyk's Avatar
Question 98mm ftp lid
ive inadvertantly installed the ait sensor in flat part of the lid...will this affect the hp & tq numbers...also will this be ok...
Old May 9, 2013 | 08:05 AM
trans_am7935's Avatar
i did the same thing on mine before my H/C/I install and it worked just fine for me, i later upgraded to the ZO6 85mm MAF and used the IAC off the MAF for better readings
Old May 9, 2013 | 03:06 PM
AmarilloWS6's Avatar
Might cost a little bit more but if you're getting your car tuned soon this is the way to go. My ws6 had the 98mm lid with an 85mm MAF from a Silverado and it had the built in IAC sensor in it that gave it a clean look, and with the MAF turned sideways and the wires hidden it look like you're running a speed density tune. Mine was solely a cosmetic issue for me but if it nets better readings that's a plus too!
