cam sensor question
Old May 20, 2013 | 02:11 AM
Camaro9969's Avatar
Default cam sensor question
So I have had troubles on start up car was always perfect started within 3 seconds. Lately had horrible start ups sometimes I have to turn it over for a few seconds shut it off try again basically do it over and over till it fires because I didn't want tto just let it keep turning over. (Also my teach stopped working) so I figured bad cam sensor. I replaced it wires looked good and same thing happened. I went in HP tuners unchecked the box for cam position sensor and now my tach works but same terrible start up. Anyone have any ideas on this??? I can't figure it out since its been perfect but randomly started doing this.
Thanks
Old May 20, 2013 | 02:53 AM
Ron_Stoppable's Avatar
change the CRANK sensor out. check the wiring also/
Old May 20, 2013 | 05:04 AM
Camaro9969's Avatar
If the crank sensor was bad it wouldn't even start I thought??? Because it runs fine it's just the starting that is not smooth
Old May 20, 2013 | 06:26 AM
yeah but ya never know... imo i think its a wiring issue. are you throwing any codes?
Old May 20, 2013 | 07:02 AM
Camaro9969's Avatar
I think it's wiring too I just can't find where it's bad ....can I wire it up myself ?
And ya it's throwing the bad cam sensor low voltage
