TSP true duals to CME help
Old May 26, 2013 | 05:58 AM
camarodude87's Avatar
Default TSP true duals to CME help
Hey guys,
This is what I got and what im trying to do. I have TSP true duals that dump before the axle. They are 3' all the way back. I just ordered a CME kit from 6LE. Well what i'm wanting to do is cut off the dumps and run a pipe from the bullets up to the CME. I want to be able to unbolt the exhaust from the bullets in case I want to do some maintenance on the rear or some freak **** happens. Ive seen a pic or a thread of it being done but there are so many True dual threads its quite a task. Anyone know where I can find that thread of the person who done it chime in.
Now I thought of two things. Use two of the clamps that came with the TSP dual kit, or use 4 flanges. What do you guys think the best course of action will be for me?
Anyone even using those clamps that came with the TSP bullet kit, I see people just weld the exhaust. Any advice would be appreciated. Ill post pics pics after I finish my school... <---yup
Old May 29, 2013 | 05:03 AM
any advice.. ****
Old May 29, 2013 | 08:34 AM
Midnight02's Avatar
Can't offer any advice however in theory I like what you're trying to do...bump it up hoping someone else can help.
Old Apr 18, 2015 | 01:49 AM
caturnbull1's Avatar
i know its an old thread but did you end up doing this? how did it come out
Old May 28, 2015 | 08:30 PM
I did end up doing this. I took 4 90deg bends and made it work. However the rasp was so unbearable and I had issues with my cme I cut it all off and sold it. I do have some pictures I can upload
Old May 29, 2015 | 07:04 PM
Powers00SS's Avatar
I thought true duals eliminated rasp? Just curious because I am thinking about getting the tsp dual setup and perhaps eventually adding in the CME but if it makes it raspy I will likely pass. Thanks!
Old May 29, 2015 | 10:39 PM
Empatho's Avatar
I have bassani true duals matched to a CME and it has a tiny hint of rasp around 2300 rpm, there was no hint of rasp before the CME. After the CME the exhaust got a little louder inside the cabin. But the CME looks too good too give up, so I put up with the bad side effects.
Old May 29, 2015 | 11:10 PM
Yeah you know it looks good yeah. However I couldnt stand the sound.
Old May 31, 2015 | 11:07 PM
Empatho's Avatar
I put sound deadening on the car ant it helped a bit with the exhaust noise. If I didn't have the CME already I would get this one and not worry about the noise.
