TPS showing 2% at idle.
Old Jun 24, 2013 | 02:35 PM
BJSS25's Avatar
Default TPS showing 2% at idle.
It will be showing zero but soon you crank the car it shows 2%. Tried different things, re-flashed PCM, cleaned the TPS, and tried another TPS. Still same result, checked grounds, and connectors. Nothing has been changed on the the car. Any ideas?
Old Jun 24, 2013 | 02:52 PM
luigiandme's Avatar
Does it change at all when you turn the throttle blade?
Old Jun 24, 2013 | 03:02 PM
BJSS25's Avatar
Yes it changes.
Old Jun 24, 2013 | 07:19 PM
S10xGN's Avatar
Why would you think that's not normal? When an engine is running, the throttle blade(s) must be open to some degree...
