Removing power steering pump..truck bracket ????
Old Jul 6, 2013 | 01:59 PM
jaywill's Avatar
Default Removing power steering pump..truck bracket ????
2 of the bolts r completely loose.... 1is hitting pully !!! Do i have to remove the pully ??
Old Jul 6, 2013 | 02:19 PM
jaywill's Avatar
Its pissing me off !! !!!
Old Jul 6, 2013 | 02:43 PM
Streetlegal?'s Avatar
you need to pull the bracket out and back the bolts out at the same time so that you can turn the bolts out of the head. Basically you slide the pump bracket out along the bolts as you unscrew them. It's a PITA.
Old Jul 6, 2013 | 05:32 PM
jaywill's Avatar
I did that I got the bolt out as far as it will go...it won't turn anymore.. I can hardly get the wrench o. it now
Old Jul 7, 2013 | 08:13 AM
garys 68's Avatar
why not remove the pulley? your new pump will probably need it swapped over anyway.
Old Jul 7, 2013 | 10:49 AM
jaywill's Avatar
i c that now !
Old Jul 8, 2013 | 09:35 AM
Originally Posted by jaywill
i c that now !
Or you can just drill holes in the pulley. I did that too ha.
