5.3 swap
Old Jul 19, 2013 | 11:15 PM
Cstan14's Avatar
Default 5.3 swap
so i bought an 01 5.3 to go into my 99 z28. the ls1 spun a bearing.. so i bought the 5.3 to replace the ls1. im 99% sure the truck engine was an automatic. tell me if im correct, but to swap the 5.3 into my 6 speed z28 all i need to switch over the flywheel and pressure plate etc onto the 5.3 right and shouldnt have issues? please let me know, thanks!
Old Jul 20, 2013 | 04:13 AM
garys 68's Avatar
If it came from a manual truck, it will have a pilot bearing in the outer crank flange. That will need to be removed. You'll need a 98-02 f body pilot bearing installed in the inner flange.
Use new truck flywheel/crank bolts with sealer on them from a GM dealer. The sealer prevents oil from leaking through. Use locktite thread locker on the crank and pressure plate bolts.
Old Jul 20, 2013 | 09:58 PM
Cstan14's Avatar
and if it came from automatic?
Old Jul 21, 2013 | 04:29 AM
garys 68's Avatar
Just the 98-02 f body, pilot bearing, flywheel and clutch.
