Torquer v2 Cam looking for more power, ideas and gains
Old Jul 23, 2013 | 12:23 PM
mokszya21's Avatar
Default Torquer v2 Cam looking for more power, ideas and gains
I just got my 99 Trans am Firehawk tuned at beyond redline and dyno numbers were 392rwhp and 365 torque. I am thinking about going to Fast 102mm manifold and nick williams throttle body and 100mm maf. Any ideas on how much I would gain from this setup? My mods are Torquer v2 cam, BBK 85mm manifold with 85mm throttle body. 243 ported heads. bbk longtube headers with off road y-pipe. volant cai. Magnaflow exhaust. Any input would be nice or someone running the FAST setup.
Old Jul 23, 2013 | 03:03 PM
thunderstruck507's Avatar
Probably around 10rwhp, maybe more maybe less depending on where your car made peak HP at.
Going to be an expensive upgrade for the gains though.
Old Jul 23, 2013 | 03:55 PM
HCI2000SS's Avatar
I agree with thunderstruck...maybe 10-15 at the wheels
Old Jul 23, 2013 | 04:07 PM
MikeWS6's Avatar
I am in the same boat as you. I am doing the VR ported Fast 92 > the 102 because it requires wayy less parts.
Old Jul 23, 2013 | 04:28 PM
JakeFusion's Avatar
Super Hulk Smash
My FAST 102 required a take-off LS2 fuel rail. That was it.
Then you just get LS2-style (EV6) injectors from FIC and it comes with the correct adapters (which are no more expensive that EV1 injectors).
LS2 waterpump is optional if you run a 102mm TB and you don't want to grind your stock, old *** WP.
Old Jul 23, 2013 | 05:13 PM
mokszya21's Avatar
peak horsepower was at 6200rpms
Old Jul 23, 2013 | 06:01 PM
sreve's Avatar
That's a couple hundred low isn't it?
Old Jul 23, 2013 | 07:15 PM
HCI2000SS's Avatar
Nah, 6200 peak is about right
Old Oct 12, 2013 | 04:41 PM
mokszya21's Avatar
Default Vengeance 92mm fast
YEah I am also thinking about doing the 92mm fast. Did you do yours and what type of results did you see? Was it worth it to you? Thanks
Old Oct 12, 2013 | 10:03 PM
badazz81z28's Avatar
Not really. All you need is an LS2 rail and the spacer kit from cbm. I'm running the LS1 injectors too. The Ls1 rail wasn't difficult to sell to recoup some cash. The FAST 102 is a superior intake to the 92mm
Old Oct 13, 2013 | 12:19 PM
MikeWS6's Avatar
Im just going to keep the ls6. Dont really care about the 15hp gain anymore.
Old Oct 13, 2013 | 04:31 PM
TXZ28LS1's Avatar
Id spend the money on heads instead of fast intake.
Look into WCCH, TEA LS6 heads..
Old Oct 13, 2013 | 07:15 PM
z-maro's Avatar
You could look at 1-7/8" headers and 3" Y or duals for some more power too.
Old Oct 14, 2013 | 04:25 PM
ls1jorge's Avatar
Keep the same setup & install a D1SC procharger.
Old Oct 14, 2013 | 05:44 PM
That's actually some good advice. You could take a completely stock LS engine, slap in a Pro-charger and be at the same power level as a HCI car. I wish I knew that from the get go. I saw a stock LS3 on tv the other day with a SLP SC, 480 to the tires on a stock engine. I think its by far more economical when you consider the consumables that go along with a Head and Cam swap.
