Ignition coil question
Old Jul 31, 2013 | 07:09 PM
The_Bishop's Avatar
Default Ignition coil question
Potentially stupid question inbound:
Will these fit an LS1?
http://www.ebay.com/itm/OEM-IGNITION-COIL-PACK-12573190-WITH-BRACKET-FOR-LS1-LS2-LS7-/171060292192?pt=Motors_Car_Truck_Parts_Accessories&hash=item27d3fcea60&vxp=mtr
It's all 8 coils, both brackets, and both wiring harnesses.
I have a set of used truck coils (The 585 ones, with the heat sink) but I'll need to screw with the mounting brackets to make them fit. Figured I could sell them and buy something that'll bolt on with no headaches, and be new.
I know it says LS1 in the auction, but figured I'd double-check.
Old Aug 1, 2013 | 04:16 AM
LS1MCSS's Avatar
Yes, they will fit.
Old Aug 1, 2013 | 07:26 AM
The_Bishop's Avatar
Ok, thanks. Just wanted to make sure they'll fit before hitting the 'buy' button.
Old Aug 1, 2013 | 08:38 AM
thunderstruck507's Avatar
Those look like some variation of truck coils...they might not fit better than your current truck coils.
Do you not have the stock ls1 coils on hand anymore? If there is nothing wrong with them there is no reason to replace them.
Old Aug 1, 2013 | 09:11 AM
The_Bishop's Avatar
Well, yes and no. I have the stock LS1 coils for my '98. I'm in the process of getting stuff together for a heads/cam swap (ported 243 and EPS cam) so I'll need the coils/brackets/wiring for the newer mount setup.
