timing twister
Old Aug 1, 2013 | 09:16 PM
hershey1's Avatar
Default timing twister
I hooked up a msd timing twister and the car is running horribly. The red led is flashing which is suppose to tell me the twister has not learned the cars timing from the crank and cam sensors. The manual says it should run in pass thru mode when the light is flashing, this does not seem to be the case. I have all dials set to zero so even if not in pass thru it should be doing anything with timing.
Has anyone expeneced this. Not sure how long to give it to see if it straightens out.
Thanks
Old Aug 2, 2013 | 06:50 AM
hershey1's Avatar
Bump to the top
